The following example enables DHCP Snooping and Dynamic ARP Inspection (DAI) on VLAN 100 and IP Source Guard on authentication port:
Auth-Type := Local
User-Password == "000000000001"
Service-Type = Administrative-User
Tunnel-Type = VLAN
Tunnel-Medium-Type = IEEE-802
Tunnel-Private-Group-Id = 100
Extreme-Dynamic-Config = "DHCPSNOOP"
Extreme-Dynamic-Config += "DAI"
Extreme-Dynamic-Config += "IPSG"
The following example configures the Custom Auto-Negotiation Advertisements (CANA) to 100Half on authentication port:
Auth-Type := Local
User-Password == "000000000008"​
Extreme-Dynamic-Config = "AN-ADVERTISMENTS:100H"
The following example enables BPDU Guard on authentication port:
Auth-Type := Local
User-Password == "000000000006"​
Extreme-Dynamic-Config = "BPDU"
The following example enables DHCP Snooping and DAI on the platform VLAN associated with I-SID 10000 and IP Source Guard on authentication port:
Auth-Type := Local
User-Password == "000000000002"​
Fabric-Attach-ISID = "0:10000"
The following example enables IGMP Snooping on VLAN 100:
Auth-Type := Local
User-Password == "000000000003"
Tunnel-Type = VLAN
Extreme-Dynamic-Config = "IGMPSNOOP"
The following example enables IGMP Snooping platform VLAN associated with I-SID 10000:
Auth-Type := Local
User-Password == "000000000004"​
The following example enables reauthentication on a port without a configured time interval:
Auth-Type := Local
User-Password == "000000000007"​
Extreme-Dynamic-Config = "REAUTH"
The following example enables reauthentication on a port with a configured time interval:
Auth-Type := Local
Extreme-Dynamic-Config = "REAUTH:1230"
The following example enables SLPP Guard on authentication port:
Auth-Type := Local
Extreme-Dynamic-Config = "SLPPGUARD"
The following example enables EAP traffic-control on authentication port:
Auth-Type := Local
User-Password == "000000000005"​
Extreme-Dynamic-Config = "WOL"
The following example triggers a PORTBOUNCE on the port that authenticates the user. :
Auth-Type := Local, User-Password == "000000000001"
Extreme-Dynamic-Client-Assignments += "create=vlan, pv=300, vni=100300",
Extreme-Dynamic-Config += "PORTBOUNCE"
